The RED cross will not align with green,(off to the left). Found that this is a common problem. Ordered 2 STK392-180 chips from Bluestar yesterday. Need to know if and how to remove the TNP2AH046 board for repair at work. I have access to temp-controlled soldering pen and vacumn.
SOURCE: Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
SOURCE: PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
SOURCE: Panasonic PT-47WX53G Projection TV - convergence problem, can not align completely
I don't know why that guy told you to replace your "DC" board (that is the one you mean, right?) More likely than not, it's your convergence amp integrated circuits (ICs). I had what I think was the same problem (on the same exact model TV) you described, and I looked around alot of blogs and DIY websites, and this seems to be the most prevalent root behind these convergence problems. I ordered the two chips for twelve bucks (for both), spent a few extra bucks (like $35) on some electronic tools / solder supplies, and followed procedures laid out here at http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html, as well as paying strict attention to the service repair manual (which you said you already have?). The result? No more convergence problem, and I saved myself around $400 - $550 over having it done by a professional.
Seriously-- I bet this is the culprit. Just make sure if you're gonna do this that you FIRST check the six resistors (located at spots D-7011 thru D-7016) to make sure there are none burnt out / opened. It may be that one of those is fried also / instead. Since they are far easier to replace, it's good just to rule them out first.
And by the way, just FIY, when I did this I had kept the TV unplugged for about two weeks first, cuz I wanted to make sure all the capacitors were discharged and safe. Did I need that much time? Maybe not (some have said a few hours is sufficient), but I was also primarily concerned about the Flyback Transformer and its wires, which have the highest voltage (up to 30,000 volts) and can hold a charge pretty long. And I'm still here to write about it. So, check out the link, and see if you'd like to try this yourself, as well!
