The suggestion that I go to Ace Hardware for a replacement cord for my coffee maker was helpful. Ace had the right power cord. Thank you.The suggestion that I go to Ace Hardware for a replacement cord for my coffee maker was helpful. Ace had the right power cord. Thank you.
You can't post conmments that contain an email address.
It seems like you're facing a challenge with finding a replacement 220V water inlet valve for your Horizon 2000 washer. Given that the original part is no longer manufactured, here are some suggestions to consider:
1. You can try looking for a universal water inlet valve that is compatible with 220V. Universal valves are designed to fit a variety of washing machines and may serve as a replacement for the original part. Be sure to check the specifications and compatibility of the universal valve with your washer.
2.Contact local appliance repair shops or parts suppliers. They may have access to a stock of older or hard-to-find appliance parts, or they might be able to source a compatible valve from a similar appliance.
3.Check online marketplaces, such as eBay, Amazon, or specialty appliance parts stores, for discontinued or rare parts. There might be sellers who stock old appliance parts, including the 220V water inlet valve you need.
4.Some retailers specialize in sourcing hard-to-find or discontinued appliance parts. You can try reaching out to them to see if they can locate the specific valve you need.
5.If you are unable to find a direct replacement, you might consider using a voltage converter or transformer to adapt a more common 110V water inlet valve to work with your 220V washer. However, this approach can be complex and may require electrical expertise to ensure safety and proper functionality.
6.If you're having trouble finding a suitable replacement, consider consulting a professional appliance repair technician. They may be able to offer alternative solutions or suggest a compatible part that can be adapted to your washer.
It is possible to obtain a replacement water pump for a Siemens Lady 45 dishwasher, but it may be difficult to find one as the dishwasher is no longer being produced and may be considered an older model.
One option could be to check with Siemens directly to see if they still have any replacement parts available for the Lady 45 dishwasher. They may also be able to provide you with the contact information for a authorized service center near you.
Another option could be to check with appliance repair companies or online retailers that specialize in selling replacement parts for older appliances. These companies may have a limited stock of replacement water pumps or similar parts that can be used as a replacement.
It is also possible that the water pump can be replaced by a compatible one from other brands, in this case you can check with a appliance repair technician or parts supplier to see what other options are available.
If you need a replacement motor coupler for your Ronson 8342 stick blender, there are a few options you can try:
Check with the manufacturer: Contact Ronson customer support and inquire about the availability of a replacement motor coupler for your specific model of stick blender. They may be able to provide you with a replacement part or direct you to a authorized distributor.
Check online retailers: Look for online retailers that sell parts for small appliances, such as Amazon or eBay. You may be able to find a replacement motor coupler for your Ronson stick blender.
Check with local appliance repair shops: Local appliance repair shops may carry the replacement parts you need or have the contacts to help you find them.
It's worth noting that finding replacement parts for old appliances can be difficult and that's why it's always better to check with the manufacturer first.
Also, you might want to have the model and serial number of your stick blender when reaching out to the manufacturer or other suppliers, as it will help them to identify the correct parts for your specific unit.
It may be possible to find a replacement gasket for your older Marvel 2 zone beverage fridge. You can try contacting Marvel customer support to see if they have any gaskets available for your specific model of fridge. You can also try checking with appliance parts retailers or online marketplaces to see if they have compatible gaskets available for sale.
As for the drip tray that is splitting due to ice forming, it may be possible to replace the tray. You can try contacting Marvel customer support to see if they have any replacement parts available for your fridge, or you can try checking with appliance parts retailers or online marketplaces to see if they have compatible drip trays available for sale.
It's important to note that finding replacement parts for older appliances can sometimes be difficult, so it may be necessary to search multiple sources or consider alternative options if the desired parts are not available.
To obtain a drive belt for your Gear Smith candy floss machine, you may want to try the following options:
Contact the manufacturer or a customer service representative: The manufacturer of the candy floss machine may be able to provide you with a replacement drive belt or refer you to a distributor or retailer who carries them.
Check with a local appliance repair shop: An appliance repair shop that specializes in small appliances may have drive belts for your candy floss machine in stock, or be able to special order one for you.
Check online retailers: There are many online retailers that sell small appliance parts, including drive belts. You may be able to find a drive belt for your candy floss machine by searching for it on a website like Amazon or eBay.
Check with a local small appliance store: Many small appliance stores carry parts and accessories for a variety of appliances, including drive belts. You may be able to find a drive belt for your candy floss machine by visiting a store in your area.
It's a good idea to have the make and model number of your candy floss machine on hand when searching for a replacement drive belt, as this will help ensure that you get the correct part.
Hello, Are you one to open your machine and do the cleaning, oiling and gerneral maintenance of your machine? I do and I have good results buying replacement parts online. I checked out one site and they answer emails for people looking for new or used parts. They "harvest" from older machines so they may have the part you need. This of course only works if you or someone you know is handy working on small appliances. The site is: [email protected]. Good luck, Germaine
There's a Hot-to-Neutral short in the microwave that is revealed whenever you turn on the microwave. FIX: fix (or replace) the microwave. The fuse blowing is preventing any fire that would otherwise develop. PROBLEM: small appliance manufacturers don't offer for sale replacement parts. So, even the handiest repair person is thwarted when a part breaks. WHY: Small appliances are considered to be "throwaways" by US consumers - few consumers have repair skills, and small appliances are cheap, and therefore simply run until they stop/malfunction/blow fuses/pop breakers, and are then replaced. Major appliances are those expensive enough to justify selling/distributing replacement parts - washing machines, dryers, cars, TVs, etc. TO TRY: give your microwave to the nearest handy repair guy/kid in the neighborhood for repair, and realize that the chances you'll get back a working microwave are slim to none. THE FIX: You're forced by your fellow consumers to do what they do - buy a new microwave.
