Tried winding a bobbin and thread round under bobbin instead. Had to take bobbin and bobbin case out to get all the thread out and now after putting bobbin case back in machine the proper way the needle won't pick up the bobbin thread and the thread through the needle is getting stuck on something when the threaded needle is in the down position while trying to pick up the bobbin thread without success.
i have this same problem, I also changed needle. I have been sewing on this machine for over 2 years...someone please help!!
front needle not picking up thread singer 10uj13
My singer Brillance sewing machine has stalled, the needle will not move up and down. I have re-threaded multiple times with no results. I have taken the bobbin case out and replaced multiple times. The machine continues to stall making no noise or not sewing. It shows a C3 in the window. What does this mean?code singer
I have a singer machine the needle is not picking up the bobbin thread and is not sewing at all
How do i thread machine to fill bobbin? And i have the needle mechanisms disengaged but the bobbin won't spin! My machine is the Singer 401A
how to put back bobbin case on singer model 9015
The needle dosn;t take out the bobbin thread, this is why i can't start sewing!
thread get stocked between the hook race and the Bobbin Case
My machine will not raise the bobbin thread.
I cant get the bobbin thread to pull up, the top thread just gets stuck
how do I take the machine apart to fix the timing
The Extension Table, not the Bobbin Case, I purchased as an original part for the Singer 7422. The opening slot should be 3.5" Wide x 7" Long so that it can connect where the original case would normally connect. The size of the Extension Table Opening is 3.5" Wide x 5" Long, which does not allow for proper attachment to the machine.
does thread enter needle left to right/
everything was fine untill i changed needle now bobbin case wont move without me litely pushing it than goes around and stuck again same spot
my singer 20u needle is stuck in the down position just before feeding the material.
I cant put the bobbin case back in the machine
how do i get my bobbin case back in machine
