Jvc stereo subwoofer amp output only has one rca output and my subwoofer amp has 2 inputs. stereo instructions show amp only having 1 input, so do i have the wrong amp for my deck or what?
SOURCE: jvc kd-g720, hook up eq
yea but you will only have control on the low side of the eq. your beter off using that eq for your mids and highs
SOURCE: My jvc kw-avx800 has a one rca out for the
Use only 1 RCA - as each time you split your signal - so too does the voltage. If your head unit gives a 2V audio signal - and you split it, you are only amplifying a 1 volt signal now. Its a little dirtier, and makes your amplifier work less efficiently when you divide it. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
