It seems that your messages are full. This will happen if you dont delete all messages. Try that first. Then try the answer button. Sometimes we turn it on but forget to actually have it answer calls. Make sure your rings are set to 4 rings then you will know if it will answer after 4 rings. If it still won't answer after 4 rings then junk it. They are so cheap to buy a new one. They are not worth fixing these days. it is sad i know.
Good Luck
SOURCE: Own a GE 29870GE1 telephone with digital answering
Try unplugging the phone from the wall power outlet plug it back after like 3 minutes. Power on and see if you get a dial tone, if not, try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn
off the phone, remove the AC adapter, press and hold the page/call
button that is on the phone and plug back your Ac adapter, this will fix
the problem.
Take care.
I can play the message on the answer machine, but when the phone rings, if I do not pick up the receiver, it simply rings out. How can I make the answer machine work? Thanks for your suggestions.
Carmen
