My drill's charger gets hot and I smell of burning plastic when I blog it ,also it doesn't charge?
SOURCE: Drill Started Smoking Now won't run
An overload could not cause catastrophic failure. Try contacting the manufacturer via internet and ask for their info on your product. If useful print it and bring back to the tech. DO NOT GIVE IN TO THEIR BULLY TACTICS. The 1st rule of any business is "The customer is ALWAYS right" Bring the tool back to where u bought it and demand a full refund.
SOURCE: chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
SOURCE: Kawasaki drill charger
no warranty ?
well,as for me,i would rather find any DC charger that suits the voltage output for the battery..
smaller ampere gave longer recharging time but keep your battery cool during charging...
SOURCE: Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA The one I have is a Ktec Model KA12D240020034U
SOURCE: my chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
It's probably the switch; mine judders and works kind of. Slight burning smell coming from it, dismantled it to discover that the switch has started to burn out, so far no luck finding a replacement.........
JCB are totally useless, no help from their support phone number!
