Greetings...
You need to have a computer with a wired connection to the router to make this change... this is a Toshiba PCX5000?
open a browser and type in 192.168.100.1
it will ask for a password or make you setup a password, make sure you write password down... if it asks for a password and you do not know it, you will have to push the reset button and reset the router to factory specs and then add a password...
after accessing the router... in the left hand side bar click on wireless...
goto the wireless settings...
Wireless Net Name entry box - Also called the ESSID, the Wireless Net Name is the unique name
shared by all devices on the wireless network. All wireless devices on the network MUST use the
same Wireless Net Name to communicate with each other and the access point. The name can be
up to 32 characters long. By default, the PCX5000 uses “
PCX5000” as the Wireless Net Name.
SAVE the settings and exit the router...
Manual, drivers and other information on the router are
here
Have a great day...
Ed
Only if you lost the router login password. www.routerlogin.com gets you there, admin is username and password is password by default.
