Hello, I've a Sony Vaio VGN-FE11M laptop... last friday night, i used this as well as and i turned off ... but after then when i turned on my laptop, i'm getting just a black screen and at the starting time it makes 3 beep tones....the laptop shows the green power light, but i have only a black screen...laptop is only 9 months old....help please !
SOURCE: Dell Inspiron 1545 Booting Problem [Black Screen].
Insert the original Windows CD-ROM into the DVD-drive, and see if the computer will "boot" from that disk. If so, then it could be your 'C:' drive which is having the problem, and thus not "booting" your computer from it.
SOURCE: Sony Vaio Laptop Display Screen problem
even if ur in warranty period they wont change ur display so try to take any serivece center and change other wise in any laptop try to get
any help so first just see sony engineer get his assiant usually they use have contact where u can get serviced
SOURCE: sony vaio vgn nr160e laptop - no display
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
SOURCE: toshiba satellite p305-s8825 beeps 3 times on start up
http://www.computerhope.com/beep.htm it sounds like you have the "award bios" that means there is a video conflict or error.
remove any new hardware, undo what ever you did before the reboot. start there. if that doesnt work its a hunt and peck to find the conflicting hardware. remove and PCMCIA cards, then give it a try just keep disasembling one part at a time until the beep stops and begins to boot. if you dont feel comfortable disasembling anymore, its needs service.
