Single handle pull out kitchen faucet is completely clogged. I've replaced the cartridge, checked and cleaned both hot and cold water lines up to the connection with the fixture. Screens have been cleaned, and the flexible pull out hose and fixture have been cleaned as well as I could. When the water is turned back on and the handle is raised there is sometimes a spurt then it stops completely.
There are flow checks in either the hot and cold supply lines, or there is one on the hose. It sounds like it is failing. If it's an older model, then the flo checks will be located right at the end of the two copper tubes coming out of the faucet, and can be removed using needle nose pliers. If it's a newer model, then the check is in the hose and the hose will need to be replaced.
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
