Beeps twice continuously and malfunction light is flashing. Have emptied and cleaned filters but still won't empty
If you hear the motor running when it is to be draining you may have a busted pump impeller. Also locate and check the round looking cap it will move up and down by your hand pull it up if it is stuck at the bottom this is your float level it goes up and down with the water level the pump will not switch over if it is stuck on the bottom if it is stuck it is telling the dishwasher it is empty of water. and last but not least your wash timer may be out.
SOURCE: Dishwasher failed to drain,have emptied m/c
Hi.
The pump must be accessed, removing the hose from pump and checking from blockage.
Check the float sensor, and the pressure sensor, this devices are used to determine the water level, and if they are defective they may cause machine not draining.
If the machine does not start at all, check circuit breaker, check the fuse on power cord if cord is fused, and ensure the door lock is working.
If still no luck I suggest ringing AEG at the number listed on the owners manual.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Thanks for the advice
