SOURCE: I have a bostitch rn46 nail gun. Does the diafram
This link will show you a picture of all the parts that come in the kit:
http://www.bostitch.com/default.asp?CATEGORY=BOS_PERF_REBUILD_KITS&TYPE=PRODUCT&PARTNUMBER=RN46-RK&SDesc=Rebuild+Kit
Parts can also be ordered individual:
www.toolpartsdirect.com
SOURCE: Bostitch Rn46-1 Nail feed keeps coming
The feeder will dislodge if the feed paw spring is weak or missing. Replace with new spring to keep the feeder paw in place. Visual test with good feed spring. Remove nails and open side door. Fire gun rapidly against hard rubber or coiled air hose. The feeder should move back and fourth in time with the piston/driver. If the feeder seems to move in slow motion compared to the driver, check feeder piston orings and feeder piston spring. If both feeder piston orings and spring are in good condition, then check air passage to feeder piston chamber for obstruction. Sometimes debris will lodge in white oring where body mates to nose of gun. Good luck
SOURCE: rn46 roofing nailer wont take the nails, the
Look under the latch for debris or the check feeder pin is pushed up out of place not letting the latch close. Push the pin down into the retaining oring that fits into a slot below the check feeders. If the retainer oring is split, it will not hold the pin down.
