Samsung LNT5265F 52 in. LCD HDTV Logo
A
Anonymous Posted on Apr 06, 2012
Samsung LNT 5265 f LCD the screen is blank and is alternating betenn red green and blue the audio is on
Audio is on no video only blue green and red color
5 Related Answers
Paul Bade
  • 1818 Answers
  • Posted on Jan 26, 2009
SOURCE: Video going out on Samsung LCD
If you shine a lamp at an angle on the screen, can you see a faint image? If you can, then the backlight has gone out. If your picture has acquired a pinkish tinge while it is working "normally", this would be a strong indication that one of the fluorescent tubes in the backlight is going bad. Inverter failure is another possibility.
Samsung has a 1 year warranty. The catch is that you have to take it either to the dealer or to a factory-authorized service center to collect, and "The original dated bill of sale must be presented upon request as proof of purchase to SAMSUNG or SAMSUNG's authorized service center." You need to contact Samsung Customer Service before taking the TV in for repair.
http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=televisions&subtype=lcdtv&model_nm=LN-R377D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-R377D&menu=repairlocation
Anonymous
  • Posted on Feb 06, 2009
SOURCE: Samsung LCD Tv has no picture but sound
I took it back and got a full refund.
Anonymous
  • Posted on May 11, 2009
SOURCE: lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Anonymous
  • 63 Answers
  • Posted on Oct 02, 2009
SOURCE: NEED MANUAL FOR SAMSUNG MODEL LNT 1953H LCD 19''
..review of the product and related issues:
http://www.amazon.com/review/R2LL7LEO1ABLU8
Crutchfield's take on that model and it 'ease of use issues':
http://www.crutchfield.com/S-rsaLPNJLHDO/p_305LNT1953/Samsung-LN-T1953H.html
..more specifications from that site + related comments:
http://www.crutchfield.com/p_305LNT1953/Samsung-LN-T1953H.html?tp=161&tab=detailed_info
...manual download page for 19" LCD series:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=LN19B360C5D
Rule of thumb is check a similar product in case you can't find exactly what you want. Discussions on those other sites indicate they only have "user guides" for the LNT 1953H LCD 19" ..and nothing in the way
of serious service manuals (i.e. for the consumer).
Email me back for more info:
[email protected]
Anonymous
  • 720 Answers
  • Posted on Dec 04, 2009
SOURCE: Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Having a fault with a Samsung LCD lnt 40. Audio and video issues across all three hdmi, video issue on av in but audio good. Hope u can help. Thanks
Panel fault; suspected. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Wiring color code for lcd screen
AV VIDEO CABLEYellow- Video Red- Right sound R White- Left Sound L
Component Cables RED ORANGE- video BLUE- video GREEN-video RED- audio R WHITE-audio L
HDMI provides both video and audio all in one.
Optical out Audio Audio format to surround sound. Better sound quakl
Hope this helps
1helpful
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1helpful
Hi where is the t.con board located in samsung LNT 5265 tv
Usually it is the small board at the top middle of your set, most time it is behind a medal plate with 4 screws. There will be 2 or 4 flat ribbon cables connected to it. Hope this helps!
1helpful
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
I need to plug in a Xbox 360 into a samsung flat screen t.v using the : red yellow and white . And the green red and blue . . how should i go about this .... because im not sure wherre the cords go exactly...
You will use the red and white connections for your right and left audio, those go into an"INPUT" on the TV, then you will either use yellow, or red-blue-green for your video, not both, either yellow, or red-blue-green.
Make sure you connect all cords audio and video into the same row or group of jacks on the back or side of your TV.
Good Luck !
XBox Audio Problems
The red, blue and green are ONLY the Video outputs, and connect colour to colour, now, there are Two other connections, again coulor to coulor, usually red & white, that hook up to the Stereo INPUT. So you need BOTH sets to work IE: The Video & Audio. Video: Blue, Red, Green. Audio: Red & White.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
