Lost all my channels rescanning for the digital switchover in London as it was on ATV mode.. I need to switch to DTV mode to rescan and get them back but I can't figure out how to switch it? I found a video for the samsung B series switchover which said to power up by pressing TV and then pressing 1 to go to channel 1. Then it says to press info and then 1 again which should put it in DTV but when I try nothing happens. Any ideas?
SOURCE: dtv frozen
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote
select the Reset option. Using the right arrow button at this point
will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
SOURCE: Lost manual. How do you make TV rescan for HD
Here's the user guide. I think you might find something that can help you on page 23 of the guide (which consequently is also page 23 of the PDF document).
SOURCE: Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
