I am trying to figure out how to get inside of my printer. There are 4 white clips on the back and if you push on them they fall inside the printer...i also have a zip tie stuck inside and the paper keeps jamming because of it. i took out 5 screws already but the printer will still not come apart!!! PLEASE HELP!!!!!!
SOURCE: ink problems lexmark x2500 printer
lexmark ran out of ink replaced cartridge. still saying i am out of ink and wont print anything
SOURCE: paper jam on Lexmark X2500. Have tried numerous solutions
Please try this step if it still fails then its the problem with hardware of printer,
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: lexmark X2500 software download
Printer software is located at the following website :
http://support.lexmark.com/index?page=content&productCode=LEXMARK_X2500&actp=RECOMMEND&id=DR2768&segment=DOWNLOAD&userlocale=EN_US&oslocale=en_US&locale=en
SOURCE: paper jammed inside printer unable
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem: 1. Remove
the sheets of paper from the feeder. 2. Grab a
flashlight and look inside the feeder for any debris or foreign objects. 3. If
you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder. 4. If
feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges. 5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path. 6. If
cartridge area is clear, close the cover. 7. Rebrick
(pull out power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds). 8. When the
printer turns on, reinsert the cartridges and load some paper. Try to print
again. If problem continues,
please contact Lexmark Technical Support Center for additional assistance.
Joshua Laud started writing professionally in 2008. During his three years at University he worked freelance for various music publications including "Clash Magazine" and "total:spec," and online Data Transmission and Music is Art. Laud also specializes in technology writing. He has a Bachelor of Arts in English literature from the University of London.
By Joshua Laud, eHow Contributor
The Lexmark X2500 all-in-one multifunction printer, discontinued as of May 2011, will not install on Windows Vista or Windows 7 using the installation disc. The installation disc predates the newer editions of the Windows operating system and so you will run into difficulty when trying to install the printer. Lexmark has released up to date drivers on their website. Once you have downloaded the drivers, you can install the printer and begin using the device.
Go to the Lexmark X2500 Support and Downloads page (see Resources).
Click "Drivers and Downloads."
Install All Missing Drivers With This Driver Scan Tool!
drivermend.com/InstallDrivers
Click the link for either the "64 bit" or the "32 bit" drivers, depending on the version of Windows you are using.
Click "Download."
Double-click the file once it has downloaded. Click "Next" throughout the driver setup. Connect and switch on the Lexmark X2500 printer when prompted by the installer. Click "Restart" at the end to restart your computer.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Drive gear came off the paper feed. Need to get inside.
same issue i just want to take it apart that's all.
I am trying to disassemble my x2500 Lexmark printer
