I require tuning instructions for the above TV. I have a remote control but finding it difficult to tune the TV.
Click here to downlaod the manual. It will have all details.
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
SOURCE: How to Auto tune remote control for 1993 Magnavox
I have an older RCA universal remote control and a magnavox tv from 1993. According to my universal remote user manual (which I found online) I punched in a three digit code: 062 that worked for me, for my 1993 Magnavox TV: hope this helps!
If not, here are some others to try from my RCA universal remote user manual for Magnavox tvs---
004, 006, 008, 019, 068,069,074,075,076,077,088,089,130,131,132,133,134,183,184.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
