Set is either not getting out of standby or is in shutdown because of a problem inside.
First place to look is the power supply board--follow the power cord inside as it goes right there first.
A quick look will tell you if for example you see puffed up caps what your problem is.
These caps are puffed up and that means bad--if this a fairly inexpensive fix is possible.
If you find this and want to know what to do make a comment here.
SOURCE: hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
SOURCE: Blinking power light
Start by counting the red blinks. This will hopefully tell you what the problem is. Then check back with the number of blinks.
SOURCE: BLINKING RED LIGHT AND NO PICTURE OR SOUND
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to [email protected]
