8057 MB Disk 0 at Id 0 on bus 0 on atapi (setup can not access this disk)
SOURCE: I have a Systemax Venture computer that is 3 years
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
SOURCE: pc does not go beyond Lsass.exe application error
Try getting into safe mode, by taping the f7 or f8 key before it boots. Once in safe mode we can do a restore to the last restore point, and go from there. If you can't get into safe mode, let me know and we will go into the bios, set the machine to boot from the dvd drive and use your xp disk to boot her up, this method id too much to post here, let me know and we will take it up only if needed. Also try this, turn off any user accounts that the computer has installed other than your administrator account, and let me know what happens
SOURCE: No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
SOURCE: Systemax factory restore - how?
Tap F4 repeatedly to launch the recovery console on SystemMax Machines with the recovery partition still intact. Then you should be able to restore the machine to factory defaults without a CD.
SOURCE: need help finding drivers for Systemax Venture
go to this website http://www.systemaxpc.com/support.php
You will find them there. good luck.
it gives me 3 choices. I can press enter and let it setup on that disk is it will or I can Press C and creat a Partition in the Unpartition space or I can Press D and delete the selected partition. which on should I select?
Thank you so much...I did try D but it wouldnt allow me to delete. Also Im now getting a Error.Technical info ~ STOP:0x000000050 (0xA0A05CF8, 0X00000000000, 0XF9EA2C13, 0X000000000) NEXT ERROR INFO~ Setupdd.sys-address F9EA2 C13 base at F9E76000, DATE STAMP 41107C8F
IF ANYONE CAN HELP ME WITH THIS I WOULD BE FOREVER GRATEFUL. IM NOT A COMPUTER TECH OR ANYTHING CLOSE BUT I DO FOLLOW SIMPLE DIRRECTIONS PRETTY GOOD. THANK YOU ALL SO MUCH FOR YOUR KINDNESS AND HELP...
thank you i did try to delete. I will try again and see what it says exactly then let you know. Is there any type of free download I could get to fix my problem? I know im looking for an easy way to fix this....can anyone help? Maybe if I update a XP download or something. This is a old CD its the original CD that came with computer.
