Hi. I have a LCD HANNSPREE HSG 1116 (in Portugal). I bought it in 2nd hand, and it come without operation manual. When I was memorizing some channels using the remote control (RC), it suddenly didn't command the LCD anymore, despite of seeing the led blinking in the TV while pressing the buttons of the RC. Please help me. How can I fix it? Thanks in advance. Luis
SOURCE: changing remote command mode for sony rdr-hx525 without remote control
Hold the "Enter" button along with the numeric button for the command mode you selected in Setup. This will reset the remote to work in the command mode you selected (also lets you get back into System Menu to try other command modes). If you pick a different command mode, you'll need to do this again to reset the remote to the selected mode. Found this info courtesy our friends on the Internet - no thanks to Sony's manual...
SOURCE: Can't change channel using the remote or buttons on tv
Just run a channel scan, it should work after that.
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid
10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Contact the manufacturer they will be glad to provide one
