I need soft ware to download recordings onto my MAC OSX.
SOURCE: Olympus VN-4100PC does not register even with Vista updates
I had the same problem, but have resolved it by enabling USB access to VN-4100PC on Windows XP in a Sun VirtualBox on a Vista 64-bit host. In order to do this, you will need to have the recorder connected to the PC when you enable the USB access.
I am very relieved to have found this solution, as the Digital Voice Recorder is a wonderfully convenient device.
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
I called the number and here is the link that has the software and drivers.
http://www.olympusamerica.com/files/digitalwaveplayer.zip
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
SOURCE: Digital Voice Recorder Olympus VN 4100 PC
I found software available on an international olympus website. I was able to specify my operating system and my digital voice recorder model (VN-4100 PC) and voila, it gave me the download link for the full version software (not just an update).
I haven't actually installed it yet, so I don't know if it works but here is the link to the website: http://www.olympus-europa.com/consumer/2590_software.cfm?category=8&productgroup=347&product=&os=7&result=
SOURCE: reinstall software needed for Olympus VN-21000PC, no CDRom
I NEED THE SOFTWARE FOR OLYMPUS VN-21000PC. I LOST MINE .I NEED TO WORK ON NOE. SO PLESE DOWN LOAD THIS SOFR WARE
