Toshiba e-Studio 350 Copier Logo
Anonymous Posted on Apr 04, 2012
Fuser error 440
How to reset this error code call for service error code 440
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 31, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
3804
Points
5
Turn off copier while turning back on press 0 and 8 simultaneously then press 400.. neter value 0 then press interrupt.
1 Related Answer
A
Anonymous
  • Posted on Apr 04, 2012
SOURCE: fuser error
Blown fuse, or blown lamp or blown thermostat. Call a tech
How to solve E000001-0002 canon ir3300 error code
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ [email protected] if you have any questions.
1helpful
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
press the #2 and #8 at the same time (simultaneously)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
2helpful
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
3helpful
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
1helpful
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
8helpful
2answers
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
f9
enter
36helpful
5answers
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
