I need a recovery disc for my laptop to set it back to factory settings
If you need Download recovery disc Toshiba laptop It can be possible that your Toshiba recovery disc has been already broken and so that you want to update it without delay. A healing disc is a CD which will help you to reinstall Windows to boot your computer nicely.
You should be able to get a recovery CD for your model laptop from Toshiba.
You can download therecovery disc and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
SOURCE: I have a Toshiba Satellite M115. I'm trying to do a sys. restore
Hi Imotivate!
By far the easiest, and most probably the best option for the long run is to ask Toshiba for a replacement recovery cd. It will most likely cost you, but it's worth a shot. Finding an authorised Toshiba dealer can be found by using their helpful website tool found here : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?pf=true.
Hopefully this will point you in the right direction to get a replacement sent out to you!
David
SOURCE: Slow computer -how to restore a Fujitsu Siemens Amilo Pro v1000
If the units are running slow, you can do some maintenance on them to speed them up.
First, run defragmenter on both units.(in Safe mode)
Download ScrubXP which will automatically clear your temp, cookies and TIF files.
Download CCleaner and run it.
Run your Anti-virus program: download the free version of AVG. (Great virus protection.)
Other programs to use are SpyBlaster and Winpatrol, all of which are free.
This should help, if you feel that you need to format and restore the units, youcan do so. But try this first.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Need to set R3000 Compacq laptop to factory settings.
Compaq? Oh, then you are going to have a hard disk partition with the recovery files, so you don't need the disks. You have made it, that's great, because in case you cannot access the hard disk, you cannot initiate a recovery without ordering recovery CDs for your model from HP.
There are a number of ways to do it.
Try pressing F9 at startup (when the Compaq or HP logo shows up), and if it doesn't work, see the key for System Recovery at the bottom of the screen. It will recover, just follow the instructions on the screen.
Also, you can insert the first disk anytime, or boot from it when you start the PC up.
Or, you can use the Recovery Manager software in the PC that is pre-installed and it will help you to do a System Recovery from the files on your recovery partition.
Please rate this answer, I badly need it.
SOURCE: I need to restore my laptop back to factory settings
go on dear check the back of your laptop there is a reset button down dear opening your mind.
SOURCE: How do i restore my toshiba a105 laptop to factory setting.
if you would like to reset to factory default turn off unplug power remove battery wait 30 seconds replace batt & power hold down zero button restart pc do not release zero button until you see screen flashes and you see cursor blinking at top left release follow instructions for restore to out of box state pc will restart several times do not touch until you see choose language page this is for windows 7
