Chevrolet 1999 Chevy Silverado Logo
Anonymous Posted on Apr 03, 2012
1999 chev silvereado abs light on after changing transmission to a 2005 4L60E
Is the 2005 chevy silverado 5.3 4L60E - compatable with My 1999 5.3 . I installed the trranny now the abs light is on .The code is giving me VSS speed sensor and i changed it also . still have ABS light /still VSS code.
  • Anonymous Apr 05, 2012
    what is the code on VSS
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 36 Answers
  • Posted on Apr 05, 2012
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
36
Questions
0
Helped
21329
Points
110
Had experience in the past but not sure due to the age, some safety systems like ABS and airbag require special ECU resets often with dealers for great expense. these are often tripped due to lack of power (battery removal) or if the systems were disturbed/disconnected for access or servicing reasons. all may be operating ok they just need a computer to clear them. they just advise you that they have been tampered with.hope this helps.
2answers
1999 Chevy Tahoe. Will this transmission from a Tahoe work?
The links lead me to believe there are interchangeable. In fact this page confirms the compatible models
https://shiftritetransmissions.com/shop/4l60e_98-05_4x4/
1998-1999 Chevrolet Silverado K1500 4.3L 4X4
1998-1999 Chevrolet Silverado K1500 5.0L 4X4
1998-1999 Chevrolet Silverado K1500 5.7L 4X4
1998-1999 GMC Sierra K1500 4.3L 4X4
1998-1999 GMC Sierra K1500 5.0L 4X4
1998-1999 GMC Sierra K1500 5.7L 4X4
1998-2000 Chevrolet Tahoe 1500 5.7L 4X4
1998-2000 GMC Yukon K1500 5.7L 4X4
1998-1999 Chevrolet Suburban K1500 5.7L 4X4
1998-1999 GMC Suburban K1500 5.7L 4X4
1999-2000 Cadillac Escalade 5.7L 4X4
1999-2000 GMC Yukon Denali 5.7L 4X4
1998-2005 GMC Safari 4.3L 4X4
1996-2005 Chevrolet Astro 4.3L 4X4
1996-2005 Chevrolet Blazer 4.3L 4X4
1996-2001 GMC Jimmy 4.3L 4X4
1996-2001 Oldsmobile Bravada 4.3L 4X4
1998-2001 GMC Envoy 4.3L 4X4
1996-2004 Chevrolet S10 4.3L 4X4
1996-2005 GMC Sonoma 4.3L 4X4
https://www.google.com/search?q=1999+K1500+push+button+transmission+4WD
https://www.google.com/search?q=1999+Chevy+Tahoe+push+button+4WD+transmission+4L60E
1999 - 2006
1helpful
Abs and brake lights coming changing front brakes on 2008 Chevy silverado
Check wheel speed sensor that it was not damaged during brake job. Once the the speed sensor is right, you may not need to rest Module, it will reset upon driving.
1helpful
07 Chevy Silverado The motor caution light came on then came on the ABS light. seems like it's in third gear I hooked up the Solis I am getting three trouble codes one under the engine one under tran
Try checking the abs madule, that could be causing all the problems, such as the trans code and engine code. Also check the grounds cable maybe rusty or lose. I had a Chevy Tahoe and it was almost the same problems and it turn out to be the abs madule. Hope this helps good luck.
3answers
1998 chevy express van 3500 front brakes and rear are new, front calipers are new but ABS light on dash is on, the front brakes smoke after a little while of driving. Thanks Joe
I'd first make sure the new pads are the correct size. Doesn't happen very often but maybe the parts person gave you the wrong size pads ( for the smoking problem). As for the ABS light, most newer cars will throw out codes if you wait too long to change them out, I would contact a chevy dealer or search online about reseting the code (light).
1helpful
4answers
2001 chevy silverado 1500 AT shifting problems
is your tow/haul button pushed? is the tow/haul light burned out? i would ask myself these questions
Abs oight is on
there is a vehicle speed sensor on the transmission and one on the rearend...have those two replaced and that should solve your problem
1helpful
2answers
Plug to coil wiring on 1999 chevy malibu
if you have changed the plugs and wires you need to do a cylinder balancetest and find out what cylinder is missing after you find out what cylinder is bad check compression if it is over 100 check your injector
Top Chevrolet Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
