Not sure if its the battery or the actual charger? can only record when its plugged in
Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
I'am leaning towards the battery as the problem, but it would be worth while to check that the charger is putting out a voltage before you commit to a battery, a quick test by a repair shop is worth the time.
SOURCE: RCA cc540 VHS camcorder
Hi, Try running the camera using the AC power (charger) instead of the battery. If the viewfinder works then, it is possible that the replacement battery somehow is not suited for your particular brand/model and is not capable of supplying all the need voltages/power. Try continuously charging the battery for 16 hrs at least to see if this will correct the problem. If even in using the AC power (adapter) instead of the battery, the view finder is still off, then you have a camera fault. Normal problem for this is the thin flexible flat cable that attaches the screen to the electronics inside the camera. In some case, it is the backlight of the display that is at fault. Either which would require the services of a qualified professional. Hope this be of some help/idea to you. Good luck and kind regards.
SOURCE: Internal battery
Here's the battery you need: http://www.batteries.com/productprofile.asp?appid=254536 It's not inside the camera, it's the rectangular black box located on the back of the camera. It should just slide off.
SOURCE: RCA CC4352
check page 20 of the users manual. can be downloaded from a few sites. just type in CC4352 user manual.
SOURCE: RCA camcorder CC4352 damaged DC cable
My son has the same model camcorder so we are taking turns using the DC cable.
SOURCE: need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
