Hello . i got a problem in my tplink router thats after setting the nat and dmz followed by my ip address its still not responding while host ihave allowed the software through firewall and ihave tybed the same ip address of my Dmz to the network connection and still not working please help is there is any new firmware can fix the router bug it happense to my friend too .thanks
SOURCE: Hello , my problem is
Try resetting your router by pressing the reset button at the back. If that doesn't work, see if you can reinstall the firmware using a different method than using the modem interface. Did the manufacturer supply a CD with the modem? Maybe you can use that to install firmware as well.
SOURCE: Internet problem: I have configured my
please note that if your router DHCP is open you must close the access point DHCP if the twoic is open DHCP make a conflict and internet is stoped
best regards
SOURCE: I have a TP-Link TL-WR941ND
Can you kindly let me know the settings on your modem and router. Whether they are connected via using bridging mode or ppoe mode. In order to find this simply enter 192.168.1.1 in your browser and enter user id as admin and password as admin and hit enter. In advanced lan settings just click on first right hand side edit button and click next and see wether ppoe is selected or bridging is selected in order to ascertain the ip of wifi modem simply click on start button when connected to internet via wifi modem and select run type cmd and hit enter in the black window type tracert www.google.com wait for few seconds the first ip in the list will be your modems ip. use the same method as described above to find which way is it connected to server bridging or ppoe.
SOURCE: I am using two WAN
I'm a user 4 the same load balance product, your 2 ADSL lines must have difrent IP with difrent submask than the IP you assigned 4 TP Link-TL R480t+ (10.0.1.1 in Ur case), lets say 1st line connected to the Line through a Dlink router has an IP 192.168.1.1, this will be WAN1, its config will be as follows:
WAN Port: WAN1
WAN Connection type: Static IP
IP Address: 192.168.1.2
Subnet Mask : 255.255.255.0
Defult Gateway: 192.168.1.1
MTU Size : 1500
Pri DNS: (add the DNS here)
Sec DNS : (add the DNS here)
the second line shuld be the same way with difrent IP & difrent subnet (for example IP=192.168.2.2, Subnet Mask = 255.255.255.0 - for the router connected to the 2nd line IP 192.168.2.1 which will be the defult gatteway for WAN2)
hope this answers your question
Hosean Kobara
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
