When cooking, the electronic display started flashing, then went blank, then code F1 appeared and a beeping noise started. I reset the panel and the beeping stopped, the code disappeared, and the normal display of time and oven temperature came back on. The range burners work normally and the oven turns on, but I can not set the temperature other than the preset temp. of 350. The numbers on the touch pad no longer work.
Mine is an amana double wall oven. It beeps intermittently loosing the time readout, sometimes at least. This is usually accompanied by the F1 code readout at the display panel. When its time to bake the 350 deg can be seen at the display. The oven may light and warm up but things go hay wire and erratic thereafter.
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
SOURCE: amana wall oven
Hi~ According to the manual for this oven, the F2 code signifies - high oven temperature. The only suggestion for any of the codes in the manual is to disconnect the electrical supply. It says" pressing OVEN CANCEL pad or disconnecting electrical supply may eliminate "F code". If failure continues, contact an authorized servicer.
I hope this helps. Linda
SOURCE: F1 error on SS Amana Convection wall oven
hi in the amana fault codes it says to replace the clock.its faulty thanks
SOURCE: Temp stays at pre-bake 170 degrees oven does not ignite
We are Amana factory authorized service and parts supplies. We have all the parts that you need for you oven.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will give you all the information as well as get the correct part out to you asap.
We look forward to getting you up and cooking again.
Thanks, Ella
SOURCE: When I hit bake and then set the temperature the
The oven temperature sensor is defective.
Unplug the range or turn off the range circuit breaker.
Open the oven door,remove the oven racks.
The temperature sensor is a pencil thin metal piece about 4 inches long.
It protrudes from the rear upper part of the oven cavity.
Remove the mounting screw(s).
Carefully pull the sensor out to expose the molex quick connect plug.
Unplug the sensor.
Replace it with a new sensor.
Reverse the above order to secure the sensor and restore power.
