If your sound doesn't work you need to go to you webcam and switch the brand by open your webcam and click settings click recording and switch it. that's if when you record you cant here yourself. If you cant open your webcam go to start and start typing webcam and it will pop up! Hope it helped!!!!
i you want use it for taking picture, u need webcam software come with your laptop like cyberlink webcam to make it functioning, but if u want to use it for cam chat, you just need ym or skype to make it functioning but make sure you webcam driver is installed befor you can use your webcam.
Provided the drivers for the webcam are installed correctly, as they should be if you are using the software that was provided with the NC10 netbook, then you just need to start an application that uses the webcam....Samsung provide a program called 'Play Camera' with their Windows XP build but you can also use a messaging program such as Yahoo Messenger which lets you share a webcam.
To switch on Webcam,youmustinstall theWebcamdriversandapplications.Driversand applications,adapted totype oflaptop.Example:ToshibaSatellite L510-ST3405toWinXPoperating system.
1. Open link 2. Choose category = Laptop 3. Choose family = Satellite 4. Choose model = L510-ST3405 - click GO 5. Select operating system = Example Win XP 6. Download driver and application 7. Install driver and application 8. Open application to switch on Webcam.
The webcam light not switching on could me one of two things:
A) You don't have it plugged in, or it is plugged in but not receiving power.
SOLUTION: Try a different USB port, then go to the manufacturer's website and update the drivers.
B) The webcam is working fine, but it's not transmitting.
Some webcam's will only light up when they are transmitting video or capturing video. If this is the case, just open up Yahoo or MSN, start a video conversation with someone and see if it lights up.
You can switch between a built-in and external webcam in the program you are using. In Skype go to Settings, Camera to change it. To change webcams in MSN click Tools, Audio & Video set up, Next. For video mail in mailVU.com there is a drop down box to select your webcam.
click on the windows menu, u see a column that says "start search" .... type in the word webcam, it leads you directly to the webcam then you can operate it..
Check your webcam here by clicking on 'Allow' in top window and see if webcam broadcasts in left hand window http://www.testmycam.com/ If thats OK you need to configure your cam to WLM Open Windows Live Messenger Open Menu > Tools > Audio and Video set up - set mic as default and test > Next - set webcam as default and then trim quality in 'Settings' > Finish
