Low suction
Is the suction low at the tank after you disconnect the hose? If it is strong there, then the hose may be clogged. You can unhook the hose from the wands to see if you have suction or not. If you do, then look further down all the way to the brush roll. The other possible is if no clogs, check the filters, on the E series, there is a filter on the back, there is some also had one in the top and you would have to take it apart to get to it. One other is that the motor is not running at top speed and may have to be replaced. It can sound ok, but will have reduced suction. If you suspect the motor, check your owner manual, some of these newer ones had a long warr. period on the motor.
