Lost cd-rom
Brother has the software and drivers that came on the CD-ROM on their support site: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc465cn_all . Select your OS and the language in the menus. Download the full software from the first link (at least on the Win7 drivers list) to use all of the features of your printer. If you download just the drivers, the buttons on the multi-function printer will not trigger any action by the computer. If you need the manual, the link is: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=mfc465cn_all . Again select your language.
However, any third party software that was on the disc will not be available. (The OEM copy of PaperPort SE with OCR was on the CD for Windows systems.) You'll need the original disc or to replace the software with the full version if you use it. (You would need OmniPage to replace PaperPort SE with OCR. PaperPort and PaperPort Pro do not include OCR capabilities.) There are other programs that do this as well.
I hope this helps.
(Brother does not offer replacement install CDs for printers.)
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
SOURCE: I've lost my MFL-Pro Suite
You can download the content from here.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=-1&os=all&flang=all&dlid=
SOURCE: Brother MFC-5460CN software CD
go here, select your OS and download:
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID={B0A79ED4-F358-41B2-8CAB-E637496E2161}&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fca%2fen%2fdlf%2fdownload_top.html%3freg%3dus%26c%3dca%26lang%3den%26prod%3dmfc5460cn_all&NRCACHEHINT=NoModifyGuest&prod=mfc5460cn_all®=us&c=ca&lang=en
*please rate solution
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
