Question about Compaq Presario M2000 Notebook
Hi I have been having some problems with my presario M2000. The complete function doesn't work and when I turn the laptop on it makes a beep sound. I have realised when i hold the f1 or cap lock button then the keyboard works normally. Recently I re boot the system and I installed all driver application apart from sound card driver and it worked perfectly but as soon as I installed the sound card driver the same problem has occurred and the keyboard is not functioning.
    Master:
  • 569 Answers
Check the sound card drive
see if u have installed the same driver required by the laptop
Posted on Nov 24, 2008
6ya staff
SOURCE:
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
Hi.. I have a Compaq Presario M2000. How do I turn on the wireless. Or does it even have that. It has a wireless symbol but it's not lit up. Thanks..
Yes, it has wireless and blue tooth. Simply download the owner manual of their website. Here is a link
http://search-manual-online.com/compaq-presario-v5000-notebook-manual.html
Apr 26, 2010 | Compaq Presario M2000 Notebook
How do i turn off the scroll function on the mouse pad ? (compaq presario m2000)
Dear friend don't worry its so easy thing. You have functional in in your keyboard. Its called "Fn"
Press FN+F12 Key for turn off/on scroll function .
Thanks & waiting for your reply.
Feb 05, 2010 | Compaq Presario M2000 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Compaq presario m2000 sound card
logon to compaq website search for your model and download sound drivers
Jul 15, 2008 | Compaq Presario M2000 Notebook
My m2000 cannot power on
sounds like your sound card or power card in laptop is back feeding into your computer and make it short or cu off only way youu can fix it is to change the suggest card's and i am sure it will work better ( got time call me and i will walk you threw getting it fixed ok linda lala linda lonely2linda@yahoo.com send me a email and i will send you my tel no. ok
Jun 03, 2008 | Compaq Presario M2000 Notebook
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
201 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
