OK. Let me answer you, even if honestly I don't have any idea about an INTERTHERM FORCED AIR FURNACE. To get any answer, to a problem, you should describe your problem. Just telling that you don't know what's wrong with it is simply no enough information, even for a star expert in your INTERTHERM FORCED AIR FURNACE.
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
