SOURCE: The bulbs are gone in my main fan oven.How do I
The lenses have to be removed to gain access to the bulbs. If you look carefully at the lense, the edge immediately in front of you will have a small lip that you can get a screwdriver blade under. do so and twist the blade carefully and the lense should just spring clear. Note that the lenses have cut outs on them to ensure clearance on the bulb, so replace them round the right way.
Oven bulbs are all the same quality, so as long as you buy an oven bulb and it is the same physical size and fitting (BC or SES), you should be ok.
Testimonial: "Thanks for that we thought we would have to pull the oven out to get access.You have saved us a lot of work"
SOURCE: my stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
