I had to get a new motherboard and while taking out the old one the wires popped out and now I don't know where to hook up the new connections. please help ASAP. thanks
If you are putting in a new motherboard, the wiring may be different from your old one anyway. It's an easy project wiring up the board, just follow instructions in the manual and you will see the connectors on the wires are labelled HDD LED, POWER etc, so just look in the manual. If no manual find the make of mobo and come back.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
