Hello,When i open the laptop the screen is white and its going to purple somewheres.Whats the problem?anybody knows?
You will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
Yeah, the problem is the screen more than likely. I would bet you have a loose cable on the lcd screen.You'll have to take the lcd screen apart to get to the cable that is on the back of it at the top. unplug it and plug it back in and secure it with a piece of tape where the connections meet. Unplug the other end of the cable and plug it back. Also unplug the two cables that go into the LCD Inverter that sits under the LCD Screen at the bottom, then plug them back.
Before you take the screen apart, try plugging an external monitor on the laptop just to verify that the video card is good. The display should show up on the external monitor.
SOURCE: Armada E500 display/ screen flicker :(
Sounds like A. The LCD Lamp is going bad, or B. The screen cable is loose. If you want, you contact me directly at itolovell (at) cox.net, and ill help you diagonose, and solve the problem
SOURCE: Problem with wireless connectivity for LG-E500
i want drivers for LG500E i changed vista with XP
SOURCE: my Lg e500 laptop camera is not working and the
The solution is (even if it sound abit awkward and strange) this:
Turn of the computer.
remove battery.
start computer on ac-power
turn on computer and press F2 multiple times to enter BIOS
go to the last menu and reset settings to default settings.
save and restart computer (still on AC without battery)
when computer is fully booted, shut down again.
insert battery and boot up again.
it should now work when you start YouCam.
im not sure if all the steps are necassary, but i followed this guide and got it working !
SOURCE: LG E500
http://download.notebook-driver.com/driver/lg/E500/Vista/LGSmartCam.zip at this location ya will find the driver for vista and just reinstall the camera ...it has to work ...probably it came with a xp driver and ....
