I am trying to download itunes on my computer but i keep getting unspecified error coming up when it has nearly finished
SOURCE: since i downloaded the new version of itunes 8.0 i can't download
yes restore your pc back to before the upgrade.. Click on start then progs to accessories then to system tools...click on restore and back up system. GL
SOURCE: Keep getting error code 11222 when trying to
I have a couple suggestions for you.
First and foremost - make sure itunes can reach the internet. You need to double check that your firewall is not blocking it - if you can check the exceptions in your firewall make sure itunes is one of the unblocked programs. Otherwise, disable your firewall and then try itunes. (PUT IT BACK ON AGAIN AFTER)
Second - there could be a registry issue - Running ccleaner might solve this error - http://www.ccleaner.com/ see if that helps.
SOURCE: trying to redeem itunes and I keep getting error
Right click on "redeem" on the itunes home page. It will give you a choice to open or copy - choose "copy this link". Then paste it into a new internet explorer window. Accept the security prompt then it should load up the space to put your code in.
SOURCE: Error 450 on itunes
The 450 download error seems to be caused by either of two setups.
It is not a firewall issue.
Please do be considerate when leaving positive ratings and feedback today. Thanks to the help of itunes for this solution as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I am trying to redeem an itunes card on
TRY COPYTRANS MANAGER ITS EASY AND BETTER THAN ITUNES
http://fr.copytrans.net/copytrans.php
DON'T FORGET TO RATE
