Lexmark X3330 All-In-One InkJet Printer Logo
Anonymous Posted on Apr 01, 2012
LEXMARK 5650 HOW TO RESET INK - Lexmark X3330 All-In-One InkJet Printer
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Apr 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
5112
Points
51
HI.. TRY THIS Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one. Good Luck.
FORUM PREFERED http://www.fixyourownprinter.com/forums/printer/35235
I want to check ink levels on an HP deskjet 5650 with Windows 7
Google HP 5650 windows 7 driver go to HP website and download ututlity tools
Lexmark 5650 keeps saying out of paper
May be the sensor is dirty, also check with the troubleshooting of this printer.
Where is the printer cartridge on the lexmark 5650
hi first do not switch off the machine simply lift up the top half of the machine from the front there will be a marking and usually oval shape where your hand should fit lift up the ink cartridge will then move to the centre lift the grey latch and remove the cartridge you need to replace take the new cartridge and remove the seal and fit in position relock the latch and close the the top half of the machine it should recognise the new cartridge remember lexmark do not work with refilled cartriges and that the replacement instructions comes with the new catridge as well as in the printer driver tools under maintenance you will find it under printers on your pc good luck
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Refilled black cartridge 36 on my 5650 won't work
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
12helpful
I've refilled my black ink cartridge #36 and put it into my Lexmark 5650. My computer will not let me print - not even to "complete a page" print. It says that I need more ink. I have windows vistas. What...
Lexmark 36 and 37 cartridges cannot be refilled. When your ink levels drop below a certain point your printer deactivates the electronics on your cartridge so you cannot refill them. I own a Cartridge World ink refilling shop and I sell Lexmark originals for the 36 and 37 because of this reason. Unfortunately you purchased a machine that you have to buy expensive original ink for. You need to buy Lexmark original 36 and 37 to get your printer to work. As a refiller I never recommend someone buy a Lexmark printer if they ever want to use refills.
Ink cartridge installation
hi
you can get the user manual with instructions from here
http://images.lexmark.com/publications/pdfs/2007/index/en.html
if your having trouble opening the manual or any other documents install a pdf reader from this page - http://download.cnet.com/Foxit-Reader/3000-10743_4-10313206.html?part=dl-116442&subj=dl&tag=button/
Ink levels not real
Make sure they aren't refills. One of my HP printers never acknowledged refill quantities.
3answers
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
