Copystar CS-2050 All-In-One Printer Logo
Posted on Apr 01, 2012
I need drivers for my CS-2050 all in one printer
Where can I find a link to download the drivers for my CS-2050 All-IN One-Printer
Jim Dempsey
Level 1:
  • Contributor 40 Answers
  • Posted on Oct 23, 2013
Jim Dempsey
Contributor
Level 1:
Answers
40
Questions
Helped
42145
Points
62
2 Related Answers
Anonymous
  • 1138 Answers
  • Posted on May 28, 2010
SOURCE: unable download software for printer CS 1635 Vista basic
Hi!
Here is the file or click the url... and save the file automatically from your computer..
1. CS 1650 printer driver.
2. http://usa.copystar.com/americas/jsp/upload/resource/17858/0/1650VUP1.exe
Much appreciated if you rate this solution..thanks..
LD1908
  • 28 Answers
  • Posted on Jul 14, 2011
SOURCE: please show me the link
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=13314&rid=22655
This is for the Kyocera model but it should work with the Copystar as well. Large file but it is because of all of the drivers that are included.
Copystar cs-2050 scanner
the 2050 scanner card is an option, it is located on right side above the
network card. if you have one you will need to run a separate cable connection to a switch or router. if you are scanning to a file on computer, you will need to download a program called scanner file utility.the scanner will only work on a network connection.
Kyocera 400ci
Try this link http://usa.kyoceradocumentsolutions.com/americas/jsp/Kyocera/resource_details.jsp?pid=19349&rid=21022
1helpful
2answers
Please show me the link that I can get copystar cs 2050 driver for my printer! Thank so much
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
1helpful
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
2answers
Download software for Lexmark colorjet 2050 printer
The last driver that was developed for the 2050 is for windows 98. Don't know if it will work well with XP or Visa. But, here is the link:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Hope I have helped and have a super day!
Ron
2answers
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
