Old battery forxdsa ,modal no t0021 ,lithium ion ,rating dc 3.7v ,1100 mah ,size 2 x1.25x1/4
SOURCE: navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
SOURCE: c340 will not come on by battery or plugged into
Just purchased a battery from megacapisity on ebay. http://cgi.ebay.com/Battery-For-GARMIN-StreetPilot-c340-Extended-2600Mah_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a0Q7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem4a93233d52QQitemZ320296140114QQptZLHQ5fDefaultDomainQ5f0QQsalenotsupported
You only need to cut and splice the speaker wires.
SOURCE: how do you change lithium ion battery in garmin streetpilot c530
The unit can be opened by removing the frame around the screen. However if you are still under warranty you will void it. The battery is not an easily replaceable one since it is soldered into the unit but if you are hany with a soldering iron it is fairly straightforward. However you have to find the correct battery which you can do with an online search.
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
