Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
My clock is probably 5-6 years old, so I thought it was perhaps too early a model to brighten. I tried the snooze button 40-70 times with no luck. Then I kept messing with other buttons on top and then tried the snooze button trick again. Suddenly it was bright.
This model does not have a brightness adjustment. You can only make the display look brighter by removing the front lens.
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
