Need to set date, month etc.
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
SOURCE: Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: Tag Heuer watch runs fine; can't set time or date.
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
