the screen lights up blue that is all that happens I cannot get further plug into usb the tunes are still on the playerthe screen lights up blue that is all that happens I cannot get further plug into usb the tunes are still on the player
You can't post conmments that contain an email address.
If you press the V/T button during playback, this highlights the volume bit on the display. You can then use the plus and minus buttons to change the volume. Press the V/T button again to exit this mode.
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Make sure your operating system (XP, Vista, Macintosh, etc) is compatible with the Archos. Make sure you installed the installation CD first, before inserting the player. Restart the computer once before inserting the player. If same result, try a different usb port on the same computer or another computer.
If it still doesn't work, then go to the Archos website and see if a firmware upgrade is available for your particular model.
Choos 'Repair disk' while connected to your computer, then go onto www.archos.com go into support, downloads, choose your model and clck on download archos..... Then go into my computer click on the archos device after that has finished downloading and drag that file into the archos folder and the rest it does itself.
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
