SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
SOURCE: Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
