Keys dont work i juat wanted to know how to take a part with out force or breaking phone case.. any help at all thanks
Nokia 6500s-1 key pad of phone is not working at all. The only key that works is the on/off switch key, there after unable to access the phone
What does that mean?
Thats is very simple try to open your phone you need to use the t6 screw.if you open then you'll see the keypad flexer you need to pull out and try to back again thats all if not function you nid to buy new keypad
Dear. dear if ur 6600 key pad is not working if all are not working then u have to raplace both key pad ic located on both side of keypad connector.if only one or two key are not working then it is prob from keypad wash the contents of keypad with CTC or any approved chemical.It might also be possible that the connection of kepadcable is cut of check for connection only if some keys are not working.
Just rub the keys with the help of rubber or scracth it with twizzer or blade.
Unscrew the antena, then there are 4 screws 2 at the bottom 2 under rubber buttons at the to of the phone, just pry the buttons off with a small screwdriver, then use that small screwdriver and gently release the 2 tabs (1 on each side) about half way up. After you get it apart, gently, usung your fingers pry the chip off of the board, then the two buttons on each side, carefully slide the sides out of the holder.
Chk any key short or not
I have the same issue. At first only some of my keys didn't work. But now the END button doesn't respond and I can't turn the phone back on.
