Computers & Internet Logo
Posted on Nov 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kingston DT100/2GB Detection and Failure
I have a Kingston DataTraveller100 a.k.a DT100 having a capacity of 2GB.
I used it for a while. Later I connected it with my PC on WinXP it is saying
a USB DISK 30X USB Device...it should had said Kingston Data Traveller 2.0. Now, Detects the drive shows as Removable Disk instead of KINGSTON and displays "Insert a disk into drive".
Please respond. Thank You.
Note: I tried to format it in FAT/FAT32 and even used HP storage Format Utility. Non-Repond.
  • 2 more comments
  • Anonymous Dec 10, 2008
    PENDRIVE WITHOUT FORMAT and did not see
    4GB DataTraveler Kigston
    It started when I was running a distro by the SLAX Pendrive, and
    withdrew because I wanted to formatarlo by the Ubuntu, after we
    dismantle, both the Linux and the windows no longer recognize as the
    unit.
    On Linux:
    # sudo fdisk-l
    Device Boot Start End Blocks Id System
    / dev/sda1 1 1045 8,393,931 27 Unknown
    / dev/sda2 * 1046 19458 147895917 + 7 HPFS or NTFS
    that sda1 and another partition qeu have a backup.
    # lsusb
    Bus 007 Device 003: ID 13fe: 1d00 Kingston Technology Company Inc.
    DataTraveler 2.0 1GB/4GB Flash Drive / Patriot xport 4GB Flash Drive
    -This and only sign of life in Ubuntu, the German who always appears
    another unit "USB Disk" but it gives no information other than when
    there is no disc. And when I try to mount always says that does not
    exist, already tried with all sdb and so on.
    In Window $
    He called and a new driver with the name "USB Disk 30x USB DEVICE", the
    icon appears in Removable Disk, but when I click seeks to put some
    Pendrive! I tried the manager of records, the My Computer but it
    appears it and neither can any function. Tested these several
    applications for the recovery of Pendrive such as hp, but identifies no!
    sorry by my english ;)
    unit.
    On Linux:
    # sudo fdisk-l
    # lsusb
    In Window $
  • Pjs31 Feb 18, 2009
    I have 4gb kingston pendrive also..and i set my pendrive drive name to 'myname'.i already used my pendrive 2.4gb.and got a lots important files..when i plug in the pendrive,it will automatic install driver 'kingston datatraveler 2.0 usb device'.my problem is,when i plug out the pendrive and plug in back,it install driver 'usb disk 30x usb device' and my pendrive name change from 'myname' to 'removable disk'.and when i rightclick to properties,my pendrive change to,used space 0bytes,free space 0bytes,file system unknown.i try to scandisk my pendrive,and it cant do it,when i click ok at scandisk,it suddenly close..i try also to check with avg antivirus,it shows 'cannot open;not checked'.
    Can you please help my problem? other than format the drive.please.... really need your help.... I really need the files inside my pendrive.
    Thank you and looking forward to hear your responce.
    Best regards,
    Pj
  • team_sonic Feb 18, 2009
adhi wahyudy
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 64 Answers
  • Posted on Mar 22, 2010
adhi wahyudy
Expert
Level 2:
Mentor:
Answers
64
Questions
Helped
17534
Points
102
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
2helpful
I got a Kingston 4GB Data traveller pen drive which when plugged into the usb slot gets detected and also opens fine but when i try to send in files to it it says : "Windows was unable to save all the data...
hi,
its not a issue , down load HP low device formatting freeware , then format your usb using that software , then reboot you computer inject the usb, again format your usb in windows , use FAT32, not ntfc to format, it will for mat then try to save it it will , its nothin your usb is affected by autoexe virus it will be find if you follow what i said,
thank you,
domnickr...
2answers
MEMORY CARD NOT SHOW........?
Hi. Nokia 3110 uses microSD card up to 2GB only. Please check the size/capacity of your memory card and make sure it is 2GB or lower. Higher capacity will not be recognized.
If your memory card is below 2GB, remove the card from your phone and use a card reader to connect that to any computer and see if you can see the drive. If your memory card appears in the computer but not on your phone, you may have a bad slot but if card did not appear in your computer, you may have to consider replacing the memory.
Good luck.
I made partition in my Kingston 4 GB USB and one of the partition is not opening. I want to delete partitions to get my 4 GB capacity back.
Probably best to copy all files off and reformat it.
It would have made more sense to use folders and not partitions.
You may not be able delete the partition if you cant open it.
Does it show up in disk manager?
Hello, recently I purchased one kingston
well try using it on another PC apart from yours..maybe you have a virus that is doing it....
also format you pendrive before doing it
1helpful
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Amazing Pendrive problem
when its loaded into the memory card slot or however you have it attached to your computer right click on the assigned driver letter --> properties --> tools --> scan disk or check disk and see if it comes up with any issues
Also if this is a new memory card get a replacement that or if its too old then buy a new one
2answers
4 MB Data Traveler freezes my computer
Hi lassiebee,
Try the USB drive in other USB ports on the computer. Are you using a USB mouse and USB keyboard?
Kingston Tech Support
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
