What is the region code for the Thomson DV3631 5.1 DVD Player? Thanks in advance...........
Try this to unlock a Thomson DV3631- turn on, press Setup, should see Language options, scroll down to MPEG4 subtitle, change option there to Unicode. Hopefully this should do it.
SOURCE: DVD PLAYER MULTI REGION CODES
the number of pressing "0" ( two or for ... times ) change about model...
so check the TV screen while you press "0" for see the region setup menu ...
SOURCE: multi region code
This is not possible without bypasssing/cracking the firmware on your DVD player. your player will generally allow 3 changes to the region code. If you have not changed yet, you may do so within the DVD player's setup options.
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
SOURCE: multi region code for GPX PDL 705 portable DVD player
I hope this helps^^ try it and gimme a shout!
Turn on power.
Open lid.
Push 9 7 3 5 from the remote.
Select 0 using arrow keys.
Exit Setup.
Done.
The one above did work me,
only that after one turns on the player, enter in the 9735 with the
remote and press 'enter', you can choose between making your player
region-free or a different region in addition to R1. Select the desired
region unlock and press 'enter'.
Make sure you check the bottom of the DVD player to see if it was
manufactured in the first quarter of 2007, that might factor in whether
the code can work or not.
SOURCE: sony rdr -dc multi region code
Try this Site, may get you going:
http://www.ehow.com/how_5091093_change-region-dvd-player.html
Read Ya,
Z
