Samsung WF431ABPXAA Washer Logo
Nicole Smith Posted on May 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If a front load washer is being shipped with only 3 shipping bolts ( from korea to USA),would the washer be OK or there could be possible damage to the drum/washer in anyway?
A washer was shipped to my house ( first from Korea to USA!) and it only has 3 shipping bolts.I discovered that it should have had 4 ! Since it was shipped all the way from Korea to USA with only 3 shipping bolts,could this have damaged the washer/the drum in anyway? Should I keep the machine or return it. I have not been able to get a satisfactory answer from Samsung.Samsung said it is OK but then their manual said it should have 4 shipping bolts.Any engineers that work ,design,or build these front load washers,please help me decide.Thanks so much
  • Nicole Smith Mar 31, 2012
    Couls someone please help with this question? Thank you so much
Owen Barnes
Level 3:
Top Expert:
  • Master 867 Answers
  • Posted on May 15, 2017
Owen Barnes
Master
Level 3:
Top Expert:
Answers
867
Questions
0
Helped
399107
Points
2534
3 bolts will be ok, The drum cannot move and as long as the other 3 bolts are intact and not broken then there won't be any damage to the machine.
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jan 29, 2008
SOURCE: Damaged front Panel on Samsung washer WF206ANS, Where can I get one
If you purchased this appliance NEW, I would strongly recommending getting in touch with the company that you purchased it from. Any damage should be covered under a manufacturer's warranty and should be replaced by them. The reason I mention this to you is because many of the front panel pieces (although plastic) can cost a lot. Especially door facing trim and control panels. You can do the research yourself at repairclinic.com. Type in your model number and use the part index of photos to see if you can identify the part you need. It doesn't makes sense for you to repair something out of pocket if it is a new applaince. AND....if it was possibly damaged during delivery (if this is the case). Post back with your comments and let me know if I can be of further assistance. I hope this helps.
Anonymous
  • 15935 Answers
  • Posted on Aug 13, 2010
SOURCE: Samsung WF330ANW front load washer--was just
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • 3 Answers
  • Posted on Aug 16, 2010
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
Anonymous
  • 5 Answers
  • Posted on Sep 26, 2010
SOURCE: I am moving across the
go online to smsung.com. you should be able to buy any parts you need through them.
Mike
  • 4383 Answers
  • Posted on Oct 06, 2010
SOURCE: Our front loading washing machine
Well, if parts are not available, there is little that you can do with that machine. You can try non Samsung, like independent appliance stores, they have parts, often.
MHW6000WX ERROR F06
Possible Causes / Procedure 1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.6. Check the drive motor for powered rotations.
Need to have a list of Maytag Front Load Waher Model #s that do not require shipping bolts.
all washers ever made regardless of front or top load need shipping support when shipped be it shipping bolts or other means of synching the tub down so it doesnt become damaged by bouncing around in the back of a truck
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot (http://www.homedepot.com/Appliances-Laundry-Clothing-Care-Washers-Front-Load-Washers/h_d1/N-5yc1vZ1xr5Zbv6h/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053&omni=c_Front%20Load%20Washers). The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
WE recently purchased a front loading Frigidaire washer. I love it except we can't seem to get it level so it doesn't vibrate. It is on a concrete floor and thought the feet were self leveling but that's...
Make sure you have removed all the shipping bolts and straps. Front loaders come with bolts that go thru the back to keep the drum from moving during shipping. If you brought the washer home yourselves you may have left in these shipping bolts. Refer to you installation manual. It will give detailed instructions on how to set up your washer. If bolts are left in place the washer will vibrate and shake excessively and cause major damage if left in for too long.
17helpful
5answers
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
3helpful
Does a Maytag Neptune MAH6500WH have retaining bolts or pins that need to be installed before it can be moved?
If you are moving the washer for a long distance move, it is recommended that the shipping bolts be reinstalled to help prevent damage to the drum and suspension mechanism. This would be especially important if you're using a professional moving company, as they won't be able to move/load/unload it without problems.
If the move is relatively short and won't experience alot of aggressive movement, you can likely move the washer without chance of damage - provided you are careful and don't bounce the washer around.
Here's the info from the Maytag website, regarding moving front loading appliances:
If you are moving to a new home and plan to take your front-load washer and dryer pair with you, please call 800-688-9900, and speak to a fabric care expert. Our expert can recommend a Maytag-authorized servicer who will reinstall new shipping bolts to your washer.
New shipping bolts must be reinstalled to avoid internal suspension and structural damage to your washer during transport.
OK, so get your model number handy and give them a call, (you're missing some digits/alphas) you can get an online copy of your owner's manual that will show you the part numbers for the shipping bolts, if you've misplaced them, or give a call to the toll free number for Maytag, and they'll provide you with the part numbers needed so you can order them yourself and likely save some money versus having a service tech some out and do it for you/
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Hope you find this very helpful and best regards!
12helpful
Forgot to remove shippping bolts before using machine.
I would take out the shipping bolts and then run a prgram such as Spin.with no clothes in
If that sounds ok, wet a few towels and spin them dry
If that works put a full load in and go for it
Unless your machine was way out of balance you should not really have damaged anything.
The transit bolts are there to stop the drum from banging around during transit and unless they have torn free or have bent you should be ok
2helpful
Front loader shakes bad, is level, and on a concrete floor
You will have harmonic inbalance about 800 rpm on most front load machines, causing them to shake termporarily as it ramps up on the spin cycle. Be sure to check if the shipping bolts have been removed. This is the most common mistake most people make while installing front load machines. If you don't remove the shipping bolts, it will cause most machines to shake violently and can cause damage.
1helpful
2answers
Shaking
We have finally resolved our problem thanks to annetipu's note about someone mentioning a rod or pin that had to be removed. On the Frigidaire website, you will find the following:
14. Vibrating sounds. Tumble action washers: Shipping bolts or braces are still in the washer.
Remove 3 shipping bolts, 3 yellow spacers and 3 metal "P" clamps from the back of the washer. Remove the access panel from the front of the unit and remove 2 yellow shipping braces and large Styrofoam shipping block. Replace the access panel.
This solved our problem. Washer is wonderful now!
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
