Computers & Internet Logo
Posted on Mar 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus netbook cursor stuck
My netbook cursor is stuck. i've tried F+F3 and the screen shows touchpad on but cursor is not moving. what should i do now??
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Mar 30, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1059853
Points
15385
Make sure there is not a lock on the top middle of the touchpad that you can press to toggle the lock/unlock. if so, press it. Otherwise I would try booting up in safe mode and see if the cursor locks.
5 Related Answers
Anonymous
  • Posted on Apr 17, 2009
SOURCE: frozen touchpad
I followed the advice of pressing the FN and F7 keys at the same time. It didn't work when the program was fully loaded, but I rebooted and tried again during the rebooting and it worked. I had the frozen cursor on the Travel Mate (Acer) also.
Anonymous
  • Posted on Sep 04, 2009
SOURCE: cursor frozen, won't respond to touchpad LG X110
Press fn+f9, this is a mode for locking and unlockig touchpad
Anonymous
  • 3 Answers
  • Posted on Mar 18, 2009
SOURCE: touchpad seems to be sticking
please install ur touchpad driver again
steve6375
Steve Si
  • 395 Answers
  • Posted on Jan 03, 2010
SOURCE: dell touchpad cursor jumps
Have you installed the touchpad driver?
shredivya
Divya K
  • 71 Answers
  • Posted on Jul 03, 2009
SOURCE: synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
3answers
How to Fix Windows 7 cursor jumps backward while typing Outlook messages.
Well, technically it is not moving it backwards, it is moving the cursor to wherever the 'pointer' is.
You need to STOP resting your palm(s) on the Touchpad.
When you touch it, it will move the cursor to wherever the 'pointer' is....which is likely where you started typing.
You can also turn-off the touch-pad if you will be doing lots of typing. This is done by pressing [Fn] and [F3].
1helpful
2answers
My cursor won't move
Press F3 It should have a keypad emblem with an x across it.
4helpful
Samsung labtop cursor jumps around when typing causing all kinds of problems including highlighting and erasing entire lines or sentences!
Press Fn & F10. This disables the touchpad. You will have to use arrows or a mouse to move the cursor. This helps when you are doing a lot of typing. Press the same keys to enable the touchpad when you are finished typing.
2answers
I AM HAVING TO USE TAB KEYS TO GET AROUND THE CURSOR IS STUCK IN THE MIDDLE OF THE PAGE IT WILL NOT MOVE WHEN TOUCH THE TOUCHPAD
Try using an external mouse and see if your cursor moves. If it does that the touch pad is probably faulty and needs to be replaced or serviced.
thanks
G..
I have an ASUS P1001 Netbook, OS XP. When I am typing text, the cursor will sometimes jumps to a previous line, where my typing continues in the middle of a paragraph, or worse, when I am typing text,...
Think you might have (and it's very easy to do when you're typing) touched the touchpad as you're typing- which was probably why the cursor got repositioned. Without knowing the features on your ASUS, I'd look for Windows (assuming it's the OS) Control Panel and Mouse Controls - there usually is something that can be adjusted as to what qualifies as a tap (say, a really light tap versus a hard tap) and fiddle with it. You should be able to get it to work to your liking.
Cursor occasionally jumps sporadically when typing. Any suggestions
If your mouse pointer is randomly moving on the screen, that's probably because you're brushing up against your computer's touchpad while you type - it's a common problem. You'll get used to avoiding it over time when you type.
One option is to attach an external mouse and keyboard to the laptop, thus avoiding the touchpad altogether. Not practical, obviously, if you're using it in your lap.
Another possibility is to reduce the touchpad sensitivity - try going in the Windows control panel, then the Mouse settings, and see what options are in there. Hope that helps.
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
2helpful
Cursor is stuck even after reboot
Try typing Fn+F* where F* is a key on your keyboard wichhave a touchpad crossed out.
In my keyboard that key is the F9.
This combination puts off/on the touchpad function.
1helpful
My Asus Eee netbook keyboard seems to "cut and insert" when I am writing sentences. I will start writing and all of a sudden I will notice that it will start typing from wherever the cursor was to begin...
My eee netbook will do that too. it seems that parts of my thumbs or palms tend to hit the touchpad at times clicking the cursor on different parts of the page? could this be happening to you? try disabling the touchpad with the little silver button on the left hand side of the keyboard at the top. If this does not help, you may need to replace the keyboard. It can be ordered from the asus online store.
Hope this helps you!
Grand Canyon Tech
Grand Canyon Tech
