Replaced lamp on sony kdf 50e2000 won't turn on and blinks red, six times
I replaced the lamp assembly, secured lamp door, when turning on the tv the power light will blink three times then goes to red and blinks in intervals of six!! Help!
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
the door for the lamp is not secure properly mine did the same. now it has other issues. try to make sure the black screw for the door is all the way in
HOW MANY TIMES IS THE RED LED BLINKING? IF IT IS BLINKING 3 TIMES MAKE SURE THAT THE LAMP DOOR YOU TOOK OFF TO CHANGE THE LAMP IS INSTALLED BACK ONTO THE TV AND IS SECURE.
Hi, Question shows tv is Sony KDF-60WF655. Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen. Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure. Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem. Did you replaced its lamp in last 2-3 years? Thanks.
Did you replaced lamp in TV recently? I think TV needs new lamp as existing is either broken or dead. Lamp replacement procedure would be mentioned in user manual or let me know to provide you more info. Thanks.
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
