What else do I need to operate this karaoke system (Numark cdn25+g) ?
SOURCE: Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
SOURCE: numark dxm power failure?
i'm having the same problem, just wondeered if you found any solutions to this?
SOURCE: i just want to know
In UK the Numark DM 1002X is £99.
The Numark PRO TT1doesn't seem to be available any more.
SOURCE: need to find how to open a NXD200 from numark...
It's just the screws in the bottom that hold the top and bottom shells together Possibly some on the sides.
Do I need a mixer or a amp? What do I hook the mics up to? How does all of this go together?
Do I need a mixer or a amp? How do I hook up the mics? How does everything hook up together?
