Question about Compaq Presario 700 470024-192 Notebook
Tighten hinge on presario 700
Lcd is loose, flops back and forth
  • Compaq Master
  • 32,281 Answers
There are no adjustment available to tighten the hinges on a laptop. They need to be replaced.
These WEB site will assist you in replacing hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/b>Laptop repair infohttp://www.laptoprepair101.com/
Posted on Mar 29, 2012
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Posted on Jun 28, 2006
Anonymous
  • 29 Answers
SOURCE: Compaq presario 700 series cm2130 LCD Screen
Dear Windwalker,
Not too many screens are interchangeable, be CAREFULL ! if you are good with your hands and are willing to take it apart, the best thing to do is first rmove the battery, press and hold the start button for 1 minute,,,, this discharges the electricity stored by the capacitors in the comp. as your looking at the screen,you'll see the rubber cushions on the bezel,,,, the trim you could say around the screen,remove them and you should see small screws,FYI you may want to buy a small screw driver set if you don't have one, remove the screws.then you remove the bezel this might be tricky as the bezel is clipped around the outer sides so be CAREFULL, you may even need a butter knife to do this,but BE CAREFULL!.once you've don that you can access the screen screws. You may even want to take pictures as your going along so if you get confused when you put it back together it wont be so bad. Once you've got the screen out ,now you can get all the information on the back and do a check on a new screen. FYI if you see any liquid oozing out you must not be in contact with that, it is hazardous to health if consumed so BE CAREFULL! also shard glass is a hazard, it is manufactured micro thin so once again BE....... ok i guess you've heard it enough! if you cant find a supplier for the screen, leave a message here and i can check with my suppliers. but get all the numbers you can find on it as some suppliers will need most of them. Good luck! JLS
Posted on Oct 14, 2008
garputo22
James Heindl
  • 127 Answers
SOURCE: My monitor hinge is loose. It there a way I can
You pull up on the plastic part on the top under this there will be the screws let me know if you need more help!
Posted on Jun 05, 2009
My passenger side tie rod is loose and able to twist back n forth but doesn't come undone from the relay rod. Can this cause power steering to become stiff?
It is not likely if car has power steering the fluid may be low or if you have electric power steering it may of gone out it has happened a lot. Tie rods just fall off and your wheel will flop to left or right. If it is loose that will need to be addressed too. Good luck
Feb 14, 2015 | Cars & Trucks
How to repair a loose driver side mirror without replacing it?
I would unscrew the 3 screws and take the mirror out, to try and see why theyre not holding it properly. maybe use epoxy to fix the broken bracket and then screw the mirror back on.
Nov 25, 2017 | 1998 Toyota Sienna
Floppy stick shifter, car stuck in gear
I am sure that there are parts that are worn out in the shifter, I see this complaint a lot for Old Saturns. It will be a miracle is you can get the parts to fix the worn out bushing and such
Jun 27, 2017 | 1997 Saturn SL
Choke stuck open on 83 CJ7. Choke plate has no "spring" resistance, just flops back and forth. Solutions?
the linkage from the choke knob to the carbeurator is likely disconnected, check the linkage at the carb and follow it back from there to find where it came apart.
Apr 01, 2011 | Jeep CJ7 Cars & Trucks
How do i fix my broken driver seat? the back flops back and forth freely. 2004 mustang v6
I WOULD CHECK WITH A SALVAGE YARD, TO FIND ANOTHER SEAT THAT MATCHES, AND REPLACE IT! THAT IS THE CHEAPEST WAY!
Feb 27, 2011 | 2004 Ford Mustang
Car wont idel and revs some times for no apparent reason its a hyundai xl 1995 duz it sound like the iac valve
If it has a carberator check to make sure that the throttle linkage is in a relaxed position when the car should be idoling in other words if the linkage is too tight then while your gas pedal may not be pressed the linkage is so tight that it is still pully on the throttle linkage and causing it to rev. The only reason i can think of it revving on its own though is maybe a tension spring on this linkage is broken and the linkage is loose and flopping back and forth from idel to throttle with bumps and other distrubances.
Aug 04, 2009 | 1994 Hyundai Excel
Razr V3 wont operate out of the box
Sounds like your battery has dropped a cell
try replacing the battery
Dec 02, 2007 | Motorola Mobility RAZR V3
Compaq Presario 700 470024-192 Notebook Logo
219 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
