Garden Logo
scott Posted on Mar 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to check oil on honda gx160 - Garden
Marc Powers
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Mar 30, 2012
Marc Powers
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
82795
Points
284
There is an oil dipstick on the side of the engine. Remove the dipstick and check the oil on the dipstick.
The oil should be about half way up the threads on this engine.
If you need to add oil you can use SAE 30 or a 10W30 Oil.
2 Related Answers
Anonymous
  • 365 Answers
  • Posted on Jun 14, 2009
SOURCE: Gx160 Pressure Washer runs fine for 20 seconds Then shuts off
It could be several things...oil level, make sure its sitting on level ground...if not did you use StaBil when you laid her up for the season? If not, go to Advance Auto and buy "SeaFoam" and following directions run it for as long as it will run...make sure you have water running through the pump during tests!
Good Luck
Anonymous
  • 583 Answers
  • Posted on Sep 10, 2009
SOURCE: low engine oil how do u reset it on gx160 honda
how do you reset what?if the engine oil is low you top it up to the bottom of the filler plug hole, just so it tries to run over ,then tilt the motor back slightly and put the filler plug back in,
Honda GX160 5.5 HP Small Industrial Engine. How do I disconnect the oil alert on a GX160 engine?
Question edited for clarity, add maker and '(what is is)'.
Question moved from Cars and Trucks to model category.
Not sure why you would want to disconnect that warns you of impending catastrophic damage!
https://www.google.com/search?q=gx160+qx+disconnect+oil+alarm
Can I use 10/40w motorcycle oil in my Honda gx160
you could but I strongly suggest that you use the correct oil as bikes need special oils for reliability.
all it takes is a call to a honda service dealer to get the correct information
1helpful
Honda gx160 5.5 hp getting too hot
On most of these engines since they are air cooled you need to have all of the metal shielding that came with the engine on it. These help direct the flow of air from the flywheel fins to cool the engine. You may have to remove the metal shields and clean the fins if you have an older motor that has been run in really dirty areas. If air can't flow between the fins it can't cool. I will mention oil level just because oil also helps cool the engine how ever most of these engines will not run if the oil is low due to an oil pressure switch that prevents it from running if the oil level is too low.
3answers
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Honda 5.5 hp cuts out when not stashionary
Make sure oil is at proper level as spark is cut off when oil is below level for "x "amount of time.
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
2answers
My honda 5.5 gx160 generator wont start
Is the ignition switch turned to "ON" . Is it full of oil?
Honda gx 140 will start but dies right away wont keep running
check the oil level and top it up its most liky low and low oil shutdown is kicking in
if it still wont run try checking main jet , then try cleaning out carb and replacing plug
then check for tight in / ex valve s
cheers
16helpful
3answers
4helpful
I have a Honda GX160 5.5hp that will not start
Hi,I have an Ingersol compressor with a Honda 5.5 and found they have a low oil shut off switch.Make sure your oil level is up to normal full.
Top Garden Experts
Jay Finke
Jay Finke
john h
